The Nastran Ideas Board will be archived on November 14, 2019. Please submit any ideas to the Inventor Nastran Ideas Board instead.
Nastran Editor 2017 Queue Issues
It would be nice if when a model is running, if other files are opened and added to the queue during the run, that they would then also be run.  I just lost 10 hours of solve time because I added models to the queue of a model that was already running, and they did not run over night.  Also, on several occasions, I have had a queue not continue because after the first model in the queue is finished solving, a message box pops up and asks if I want to load the FNO file, and the solve pauses.  As I am not there and was planning for several models in the queue to run overnight, I again have lost solve time and been delayed effectively a day of work.
4 Comments
david_cordova
I like the idea of making the queue dynamic, but to avoid the problem with the message box pop ups, go to Setup > Default Settings.   In the General section increase the "Prompt to load ASCII input/output files over" to a larger value.  Then in the Post-Processing > Results Options section, either increase the "Prompt to load binary results files over" size or select the "Never load binary results files" option.
Thanks, David! I will try that. Ryan
Great comment Ryan and thanks for the reply David.
On a related note, how can we set the scratch to permanently delete the residuals at the conclusion of the run?  i don't know how to do this so they just build up there until I remember to manually delete them, or the scratch disk gets full.  I use an SSD which is fast but not very big.... it's frustrating when a long job bombs out after hours of running because I forgot to clear the scratch disk manually.
Best,
Andrew
mitch.muncy
