.XDB is not generated after analysis on Patran
Hello everyone,
After my analysis having complete on SOL 101, I have the following error message when trying to read the XDB file.
"$# Error reported from application Attach/Read Results File
$# No Results File was selected and the Results File TwoHeadedFlyswatter.xdb for job TwoHeadedFlyswatter does not exist. Please select an existing Results File."
No XDB file is indeed present in my workdirectory. What is the problem and how should I do to generate the .xdb file?
Could you please help me on this apparently simple issue please?
I attached the .bdf and .f06 files
Florian
I have the same problem, did you find a way to solve it?
John_Holtz
Autodesk Support
Autodesk Support
Thank you for contact AUTODESK.
If you are having problems with MSC Nastran or Patran software, you should contact MSC to ask questions and/or get support.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
