Problem with solver
Problem with solver
leonardo.k
Problem with solver
leonardo.k
Hey guys, I need a little help here please.
I made some analysis with a plastic bottle, pressure, and when I try to run the analysis I receive this error:
I'm already looked at this error and find this:
Autodesk Licensing Service download | Search | Autodesk Knowledge Network
Still with the same problem, and then this message show in the output tab:
I will try to reinstall Nastran again.
If someone have some ideas how to fix that, I will appreciate a lot.
John_Holtz
Autodesk Support
Autodesk Support
Hi @leonardo.k
Your options are as follows:
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
leonardo.k
Thanks a lot!!
