- Mute
- Permalink
- Report
Hi
I am analyzing a uniformly loaded rectangular plate supported along the long edges using shell elements.
The plate is 10mm thick, except at center where a circular portion is 12mm.
I have modelled 10mm and 12mm plates as separate surfaces and used surface to surface contact as bonded. However, the results show that 12mm circular plate at center does not bend along with rest of the plate. The results show that there is a kink at the boundary of 12mm plate.
How does one model flat plate with two thickness using shell elements
