Mesh refinement
Mesh refinement
Is it possible in NASTRAN to refine mesh for a local area only (something like it realize for example in Ansys, see attached picture ↓)? Thank you!
Best,
Roman
John_Holtz
Autodesk Support
Autodesk Support
Hi Roman,
I think you wanted to post your question to the Nastran In-CAD forum. (The NASTRAN forum is for the stand-alone solver which has no capabilities to mesh a model, let alone create a refined mesh. Smiley Happy)
You can specify mesh controls in In-CAD to create finer meshes in desired locations. "Mesh > Mesh Control" is the name of the command on the ribbon.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
I wanted to make sure that you saw my post, and ask you if you have any questions about the mesh controls/refinement.
John Holtz, P.E.
I find it under Mesh Control. It works, thank you!
Best,
Roman
