If I run a simple simulation (linear steady state heat transfer) where I heat up a piece of steel (length: 100mm) to 300 degrees and then taking these results to linear static analysis I get a two times greater displacement than if I calculated it theoretically.
What I am doing wrong?
Solved by John_Holtz. Go to Solution.
Hi @vanwees
I think one of these things is wrong in your setup:
If you still have a problem, feel free to attach your .ipt file to the forum, and someone will take a look at it.
John
