Hi @ahilbert3PCG3
It would be helpful for readers if you would do the following:
- Open the log file for the analysis. (Browse for it with Windows File Explorer. It is located in the folder with the name of the model > InCAD > FEA. Use the "View" menu to display extensions if they are not shown. You are looking for the .log file.)
- Copy the text of the T2020 and T2061 warnings. (The text may be on multiple lines.)
- Put the text into your reply.
Most warnings like this give the line from the Nastran file. If this is one of those situations, the first number after the "MAT1" text will show which material 1 card has the problem. You can then look at the Nastran file, find the same line, and hopefully identify the material from the property values. Then you can locate it in the Inventor Nastran interface and fix the problem.
John
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided already, be sure to indicate the version of Inventor Nastran you are using!"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
