Announcements
S1055 error modal response analysis
AndreMarcic6025
AndreMarcic6025
I face the problem with this error message "no space left on device", but there is  160GB of free space left. The error occurs when the last time step has been written to the .els file
The .els file has a size of app. 1.28 TB, does that mean that i need at least this amount of free space so that the .fno file can be written? Is there any chance to restart and finish the analysis by using the data from the .els file?
John_Holtz
Autodesk Support
Autodesk Support
Hi @AndreMarcic6025
160 GB free space is rather small when it comes to Nastran analyses.
I am not familiar with the .ELS file. Did you activate something to generate that file? Maybe it is always created but normally deleted after the analysis completes. But to answer your questions, you will not be able to use the existing ELS file to somehow restart the analysis or transfer what's there now into an FNO file. Maybe you can output fewer steps from the modal response analysis since you know the file sizes will be huge.
If you have another drive available with more free space, you should use Tips 5, 6, and 7 in the PDF document attached to my forum post Suggested Reading - Tips and Tricks on the Inventor Nastran forum to do the following:
  • See where the Nastran analysis is saving temporary files now. (Most likely "C:\ProgramData\Autodesk\Nastran YYYY".) Clear out the temporary files that are there now to recover some disk space.
  • Edit the Nastran.ini file to point FILESPEC to a different drive that has more free space.
Also, move the Inventor files to another drive that has more free space if possible.
Ideally, avoid using a mapped network drive for the analysis or FILESPEC folder. Transmitting large quantities of data over a network will take a long time and increase the analysis runtime.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
AndreMarcic6025
Hello John,
Maybe I wasn't precise enough in my description.
I started with an empty space of app. 1.5 TB and in the course of the simulation the .ELS file was getting larger. The increase was quite linear to the number of steps. After all the steps have been calculated, 160 GB were still free and the program ended with the error message S1055. I started the same simulation with a much smaller number of time steps and it was running successful to the end.
Today I increased the number of steps again (but to a much lesser number than in the first calculation) and it terminated with S1062 (also a memory space failure)
BR
Andre
John_Holtz
Autodesk Support
Autodesk Support
Your original description was clear. The analysis ran out of disk space. After the analysis ended, some of the temporary files were deleted. At that point, the drive had 160 GB free.
These are the options that come to mind:
  1. Clean up your hard disk. See Autodesk Inventor Nastran 2022 Help | What files can be deleted after a failed analysis in Nastran |....
  2. Do not output as many results. What options did you activate under "Analysis > Edit > Output"? What results can you do without?
  3. Reduce the model size. As you have found, reduce the number of steps. Perhaps there is something in the model that is not setup efficiently, such as enforced motion to applied to hundreds of nodes on a face instead of applied to one node at the center of a rigid body connector.
  4. If an assembly, can any of the parts be meshed using a linear mesh? Linear meshes have fewer nodes which will save a small bit of space. (But when scrounging for every GB of free space, every byte counts.) Note that linear elements will be stiffer than parabolic mesh for the same size elements. The "Mesh > Table" can be used to mesh some parts as Linear and some as Parabolic.
John
John Holtz, P.E.
Autodesk, Inc.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
