I use Autodesk Nastran as solver for FEMAP. I have used the following path to the Nastran C:\Program Files\Autodesk\Nastran 20XX\NASTRAN.INI. But every time I want to run the femap, the Nastran does not start automatically. In other word, I am forced to point out Femap to Nastran.exe file, then open the Autodesk Nastran, run and finally attach the results. Is it possible that when I am pointing out the femap to Nastran then it starts?,
Br
André Nedaei
Solved by KubliJ. Go to Solution.
Hi @aaneCTD3Z
Did you add the Windows Environment Variables? Otherwise, it looks like you setup FEMAP correctly.
James
Hi @KubliJ ,
Thank you for the response. I did add Windows Environment Variables and got an error in FEMAP and I can not open Preference anymore. Shall the link to solver in Tool-Preference - Autodesk Nastran still be added to an .exe file?, Or why do I get an LM_LICENS__FILE error?
Hi @aaneCTD3Z
I'm not sure what is going on. It doesn't seem to work anymore for me. Linking to the solver does not work, but linking to the editor works.
Not sure. From what I know, pre-Autodesk, NEi preferred that people linked to the editor, not to the solver. FEMAP may have changed things on their end too.
Have you checked with FEMAP support?
James
Hi James,
I was forced to delete the Environment variables otherwise I got constantly the license error. I have tried in FEMAP preference both editor and solver but non of them results in launching the analysis directly. I have tried to contact FEMAP support center in our area (Scandinavian) and as they do not have this type of solver, they can not help in this case.
BR
André
Hello James,
Sorry to come back to this issue again but I have found out that in FEMAP->Result destination->Print and Postprocessing will lead to that the Editor will open automatically, however, it makes FEMAP to crash (noted that in Preference the solver is linked to Editor). Something you have experience with?,
Hi @aaneCTD3Z
From what I recall, when linking FEMAP to the Editor, FEMAP is going to become unresponsive until the analysis finishes and closes. Is this what you are running into?
This problem is why I started to manually export the model and open the editor.
James
Hi James,
Exactly, then I continue do what I used to do, same as you described. I thought my FEMAP is unresponsive so this is simply due to the analysis is running in background.
Thank you.
