Show only
Search instead for
when a model doesn't have thickness the backside faces exposed a black matt, it is hard sometimes to work that way, it could have some options for that.
I agree. To help you out until we get this fixed (if we ever get this fixed) as a workaround you can create a new directional light and rotate it 180 degrees around the vertical. I set the intensity to .1 or so and sometimes give it a slight color, this way the inside gets colored slightly, which can be useful.
