I am sending to maya several models in the same scene after adding sculpt detail in mudbox, but Maya does not pick up the sculpt detail.
I can't see the sculpt detail on the UVs either in maya or mudbox. I tried with send preferences as both flattened sculpt layers and as blendshapes. I send the base mesh as opposed to Level 7/8 and also tried to no avail smoothing for subdivision within maya after receipt to see if the detail had been picked-up.
Here's a video , can you please help. https://youtu.be/RCkcX1pZN5E
Thank you for your help,
Sergio
Sergio
Solved by sean.heasley. Go to Solution.
Hi @Anonymous
Instead of using the send to Maya feature can you try using export selection and then import it into Maya?
Does anything changes?
Please let me know if that works or if you are still having this issue.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
All the best,
Sean Heasley
That worked ! Thanks a bunch for your help !
Sergio
Sergio
