Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Mudbox Displacement Map Test
2 REPLIES 2
598 Views, 2 Replies
i have tried out the Send to Mudbox (from Softimage) and changed the detail level (shift D), then Extract Texture Map / Displacement Map.
Question, it gave me a lot of .tif files which, which i was wondering why ?
Then when i updated Softimage from within Mudbox, in Softimage i had back the Geometry at level 0 (as i was warned that i was not on level 0 i changed it back (Page Down) to level 0), but it has not added the textures as displacement map to the model in Softimage.
Question, do i need to do this by hand ?
And will I need to add all of the .tif files ?
Frank
2 REPLIES 2
RobinBall6995
It looks like your UVs aren't all within the 0-1 range. If Mudbox finds UVs outside that range, it assumes you're using texture tiles and saves out a texture for each uv tile.
in reply to: RobinBall6995
ok thx for info.
