Hello. I know that in Mudbox 2017 you can export your paint layers out as a PSD and send it to Photoshop CC and continue working in 2D. My question is, can I use Mudbox 2017 in the same way with Photoshop Elements 14 (or the latest version)? Thank you for your time.
Solved by absoluteKelvin. Go to Solution.
if you set photo elements as your main application for opening psd files, it should work. I have mine set to a program called Krita. As long as photo elements can read and write psd files. it would work.
so just right click on a psd file> Open with> select Photo Elements> check Always use selected program to open this kind of file.
