Mudbox won't import the maya files. How do I fix this? I thinking plugins might be needed both softwares are 2018. I attached the maya file and cannot get it to send to mudbox for current or new scenes in MudBox.
Solved by mspeer. Go to Solution.
are you trying to import a .ma file.?
that does not work.
or is the "send to" mudbox feature not work.?
I have downloads fbx sdk from the Autodesk website and tried importing obj, fbx, and mb. file formats mudbox. None of these methods have worked.
Hi!
All the objects in the scene are Nurbs.
Convert the wanted object to a polygon object (quad faces with proper distribution) and Export as FBX.
Hi!
1. Main Menu: Modify -> Convert -> Nurbs to Polygons.
2. Select a polygon object
3. Export Selection ... as OBJ or FBX
