Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Import maya scene
6 REPLIES 6
640 Views, 6 Replies
Import maya scene
Mudbox won't import the maya files.  How do I fix this? I thinking plugins might be needed both softwares are 2018.  I attached the maya file and cannot get it to send to mudbox for current or new scenes in MudBox.
6 REPLIES 6
Christoph_Schaedl
are you trying to import a .ma file.?
that does not work.
or is the "send to" mudbox feature not work.?
https://linktr.ee/cg_oglu
in reply to: Christoph_Schaedl
The "send to mudbox" feature.
I have downloads fbx sdk from the Autodesk website and tried importing obj,  fbx, and mb. file formats mudbox. None of these methods have worked.
mspeer
Hi!
All the objects in the scene are Nurbs.
Convert the wanted object to a polygon object (quad faces with proper distribution) and Export as FBX.
in reply to: mspeer
Is there a way to convert the objects or do you have to create a polygon primitive.
mspeer
Hi!
1. Main Menu: Modify -> Convert -> Nurbs to Polygons.
2. Select a polygon object
3. Export Selection ... as OBJ or FBX
