I have two objects from different sources, I want them to use same/similar material so the painted colors will look the same.
If I assign the same material it will share the same painted layer, and then if I paint it it will effect both
Any idea?
Any idea?
Solved by roni.segoly. Go to Solution.
yeh that sounds right. if you use same material it will share the same paint layers
I can assign new material like 'Mudbox material' and then use same presets?
