Return filename with dialog
addisonYMRCW
addisonYMRCW
I'm coming from Maya, where you can use the fileDialog2 option to return a path and filename, then load it however you need to.  How would you do this in Motionbuilder?   I have a custom file that I need to load with a plugin script, but would like for the user to browse for the file needed.  I looked into Tkinter and easygui, but those modules aren't available sadly.
vdebaie
There is a script that comes with motionbuilder, FBFilePopup.py
You can find the contents of the file hosted here on Autodesk.com:
http://download.autodesk.com/us/motionbuilder/sdk-documentation/SDKSamples/Scripts/UI/FBFilePopup.ht...
This should help
brissef2
@addisonYMRCW ,
Was the reply above answered your question?
Best regards,
Francis
