Motionbuilder 2019 won't start
anedjaranas1234
Message 1 of 13
anedjaranas1234
Hey,
I installed motionbuilder 2019, and it won't start, the statup screenshows up, it gets stuck on restoring user interface, please wait...
I'm on windows 10, using RTX 2080 TI, and threadripper 2990WX !
Replies (12)
Message 2 of 13
buic
Thanks for reporting this. We are looking into this. This is one of the newer systems that isn't supported (yet).
Message 3 of 13
rodbrew2
I have a system almost identical to this and having the same issue.  Has been any progress on this.
Message 4 of 13
I'm also experiencing this with a new threadripper.
Message 5 of 13
buic
Could you try turning off hyperthreading? These particular systems are not working well with hyperthreading.
Message 6 of 13
rodbrew2
Did you want me to turn off hyperthreading as a test?  Is there a way to turn it off for individual programs?  I did try to set the affinity to 1 as it was loading but it still hung on that screen.
Message 7 of 13
Just wanted to chime in and let you know disabling hyperthreading (or multi-threading on an AMD system) DID fix this problem for me!  I'm also running threadripper 2990wx on an ASUS Prime X399-A.  Setting SMT mode to "disabled" in the bios was the fix.
Cheers!
Message 8 of 13
dpressler
I have the same problem, I'm also on Windows 10, using RTX 2080 TI, and threadripper 2990WX
Message 9 of 13
rodbrew2
So how did this affect the performance on other applications?  I'm pretty sure I don't want to turn off hyperthreading for rendering.
Autodesk is there any work being done on this issue?
Message 10 of 13
Yes, it will affect performance in other applications.
With that in mind, I've found myself disabling multi-threading to work in Motionbuilder and when I'm done I switch it back on.  Yes, it's a pain going back and forth like this but it is the only solution for me at the moment.
Hoping the next release doesn't have this problem...
Message 11 of 13
I had this issue, the recent update eliminated it and I no longer have to
turn off multithreading.
Message 12 of 13
buic
Hi All, We recently released an update called 2019.1. It has a fix for this issue.
https://knowledge.autodesk.com/support/motionbuilder/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
Message 13 of 13
rodbrew2
Worked here.  Thanks Autodesk.
