how can you learn via python script that your window is existing and delete it ?
I am using PySide to make UI in motion builder , but i can't find any command which will check for windows existence and if I want, to delete it.
Something like :
if cmds.window('someUi', exists=True):
     cmds.deleteUI('someUi' , wnd=True)
ThomasGryphon
My 2¢; generally I include a function at the end of my modules along the lines of
def Launch():
    try:
        test_ui.deleteLater()
    except:
        pass
    test_ui = MyMainWidgetClassName()
    try:
        test_ui.show()
    except Exception as e:
        # traceback.print_exc()
# ... or ...
# print e
Then when you create your PySide window via ModuleName.Launch(), any prior existing MyMainWidgetClassName objects (that were created the same way, in the same sesssion) *should* be destroyed.
ThomasGryphon
... Ran out of time to edit after going away to triple check and it turns out that the above^ doesn't behave the same way as it does in Maya, so something more along the lines of this (at the end of your Module)
if __name__== "__builtin__" or __name__=="__main__":
    try:
        test.deleteLater()
    except:
        pass
    test = TestUi()
    test.create()
    test.show()
Does destroy the PySide object, but I personally don't like that approach; so anyone else with a better one, by all means.
thanks to your idea , i got where to look at and this works for me :
for gui in parent.children():
    if gui.__class__.__name__ == 'testUi':
           gui.close()
