Motionbuilder 2016 what keys/mouse to rotate, pan, zoom view in Perspective view
Hi
Trying to find the answer to this, it doesn't seem to be anywhere in the manual.
On my computer, sometimes I can rotate the view, sometimes it won't work. I wonder if I'm doing something wrong so I need a sanity check
I don't like the like controls at the top of the window so would rather use mouse/ keyboard.
Sometimes I cannot select anything in the perspective view either.
- would like to know the difference between the different interaction modes too.
thanks
Depends on the interaction mode you have chosen. Interaction Mode are based on hotkeys familiar to you based on other 3D applications.
For Maya Interaction it is:
Alt + LMB = Rotate Viewport
Alt + RMB = Dolly Viewport (In and Out)
Alt + MMB = Pan Viewport
jps
The default set-up is:
SHIFT+LMB for pan
CTRL+LMB for zoom
CRTL+SHIFT+LMB for orbit
All keyboard short cuts should be here (Windows):
C:\Program Files\Autodesk\MotionBuilder 20XX\bin\config\Keyboard
3ds Max.txt
Lightwave.txt
Maya.txt
MotionBuilder Classic.txt
MotionBuilder.txt
Softimage.txt
