Mixamo to MotionBuilder Workflow
I've spent the last couple of weeks trying to import Fuse generated characters that have been rigged and added animation in Mixamo into MotionBuilder. I have found several tutorials that talk about importing and retargeting motion data but none specifically address importing Mixamo characters and animation.
Mixamo provides rigged characters with user friendly rigging and facial expression controls in a T-Pose. It also provides several thousands of short animated clips that I assume can be stitched together better in programs like MotionBuilder. I just can’t find a good tutorial that provides a Mixamo to MotionBuilder workflow which includes working with MotionBuilder Story.
Here is what I am currently doing:
- Create customized character in Adobe Fuse
- Upload to Mixamo
- Mixamo adds rigging to characters (including facial) and my choice of animation clips
- I export the characters in FBX/FBM format and I then import the rigged character and then the animation into Maya using Mixamo's provided scripts
- I only know how to import one skeleton animation (motion data provided by Mixamo) at a time into Maya.
It was recommended to me that MotionBuilder would be the best place to stitch multiple animations together into a story.
- So I save both the rigged Character in a T-Pose and the animated Actors (Mixamo's animated skeletons) starting in a T-Pose as FBX files.
- I then "Send" them from Maya to MotionBuilder and all works fine. However I want to use more than one short imported animation.
Here is where I get stuck.
- In MB I am able to characterize both the Character and the Actors in T-Poses but I can't retarget the Actor on to the Character. I select the character in the navigator and can see the Input Type pulldown has Character listed but when I try to select it, it selects Stance instead.
Do you have any suggestions on how I can retarget my Character in MB and where I can find a tutorial that specifically addresses the proper workflow from Mixamo to Maya to MotionBuilder and then retargeting (or stitching together) other animations provided by Mixamo in MB Story?
Tx Dave
