Venting / Grouping
Venting / Grouping
Brian
Venting / Grouping
Brian
The information in the help forum is rather vague on the differences between the three options for “Venting analysis locations grouping”.  My primary confusion pertains to weather all the nodes across the width of a vent must be selected when grouping is “off” or weather a single vent node assigned in the center of the vent area is adequate.
First, I am looking for an explanation to what assumptions are made for each setting.
Second, I am looking for an explanation for what nodes should be assigned as vents when using each setting.
beth.mollica
Autodesk Support
Autodesk Support
The following Autodesk Moldflow Insight Help article is useful in detailing the correct venting analysis set up
Grouping venting analysis locations
Beth
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Beth Mollica
Technical Support Specialist
beth.mollica
Autodesk Support
Autodesk Support
ON (use vent property ID and node connectivity): If you have vents on multiple locations of the part that have the same Property ID, then you would want to use the Property ID and Node Connectivity grouping.  You are putting 2 conditions on the part so that if you have 2 vent locations on the part with the same Property ID, the analysis knows to treat these as separate vents and not one large vent.
ON (use vent property ID only):  Use this is you are using a Property ID once on the part
Please also view the short Autodesk Simulation TV video on Venting analysis.  A link to this video can be found here:
Moldflow Thermoplastic Venting Analysis
Beth
Beth Mollica
