Script for "Temperature at Flow Front" for Weld Line Plot
RK1097
RK1097
How to define "Highlight/Color Dataset" to pick the "Temperature at Flow Front" dataset in the plot properties using API? I'm guessing there's a "Plot.Set___" function I can use here but looking through the Synergy API, there's no examples showing anything similar.
RK1097
After further investigation, I've found more info to edit the "highlight dataset" (see code below) but it does not work and I'm unsure what's the reason for it.
GetPlot(72) is supposed to fetch the "Temperature at Flow Front" results but the script seems to completely ignore the function.
Set PlotManager = Synergy.PlotManager()
Set Plot = PlotManager.FindPlotByName2("Weld lines", "Weld lines")
Set Viewer = Synergy.Viewer()
Viewer.ShowPlot Plot
Set Plot = Viewer.GetPlot(72)
Plot.Regenerate
