How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Made a similar post for MF2023 a while back, talked to the support and was assured everything has been passed to the Dev Team and is going to get patched but nothing ever got fixed and never heard back. Same issues have carried over into MF2024 and then some.
New Bugs I've noticed so far in MF2024:
Older Issues carried over from MF2023:
Minor issues to complain about but when you're using MF for 8+ hours a day and go through these commands multiple times, it starts to become more than just an inconvenience.
EDIT: Forgot to mention the buggy logs, every few seconds the logs copy themselves from the very beginning and keep repeating until the process ends (analysis/mesh etc). It will get fixed if you close/open the logs but issue starts as soon as a new line gets added to the logs. For example:
Hello @RK1097 ,
I noticed your first issues last week and worked with Support to create a development case internally. I agree merging the nodes will collapse/delete the "ghost" beam. You should be able to right click on the hot gate beam, go to valve gate controller to assign valve gate controllers (that should be way easier than opening 2023).
Mason
Thanks for looking into it, Mason. Hopefully your involvement escalates the case.
"You should be able to right click on the hot gate beam, go to valve gate controller to assign valve gate controllers (that should be way easier than opening 2023)."
I had completely forgotten about that, thanks for the reminder. It works, saves me quite a bit of time. I hope the bug gets looked at and is patched in the future though.
Thanks again,
Rahul.
How to buy
Type a product name
