Important selection for Moldflow Insight, using Autodesk Flex
Dear Moldflow with Autodesk Flex users,
If you use Moldflow using Named User, Network licenses or TokenFlex (TFLEX), which will be vast majority of users, this is not relevant to you.
When you use Moldflow Insight through the Autodesk Flex program, you will have to make an important choice when you submit an analysis in the Simulation Compute launch window. To help you to make the right choice for you, we put together the graph below.
Currently the default is set to “User Moldflow Insight 2023/2024”, but this may not be the right choice for your case, and you may need to use the ‘Use tokens’ option.
When you access Moldflow Insight through Autodesk flex, and use the “Use Moldflow Insight” you would be using the daily rate for Moldflow Insight Ultimate, published in the link here.
If you use the ‘Use Tokens’ option, you will be paying tokes per solver, using the published rate here.
Best regards,
Hanno
Product Manager - Injection Molding & Moldflow products
