PVT Graph comparison
mahesh_a_patil
mahesh_a_patil
I would like to understand the PVT graph comparison for two materials (Refer Image) at constant Pressure  (50MPa).
Please help me understand the attached graph, what we can conclude from this comparison?
Mahesh P
sohan.kumar.thiruvakkadu
Autodesk Support
Autodesk Support
Hi @mahesh_a_patil
Can I know a bit detail, what is the actual issue or the query you have it here?
Sohan Kumar
Global Product Support
mahesh_a_patil
@sohan.kumar.thiruvakkadu
Please have a look at the attachment. I would like to know what we can conclude from this graph. It's a comparison between the two materials at constant pressure.
Mahesh
M.Brassel
Hello @mahesh_a_patil ,
from this graph you can read that the pvT behaviour of these two materials is similar, as they have parallel curves in the diagram. These two freeze at the same temperature.
But there is a huge difference in the specific volume. The filled material with the lower curve has a higher density and will have a higher percentual volumetric shrinkage when the nominal value of shrinkage is the same, due to its smaller relative difference.
In other words: If both materials shrink by an amount of dv, the relative value depends on their specific volume when they freeze. So for the higher curve the comparison is dv / v_high and for the lower curve the quotient is dv / v_low.
I hope I made this clear enough.
Please use "accept as solution", so others may find solutions quickly. Also give kudos where suitable to further enhance these forums.
