I am currently analyzing a part that will have 2 injection units.
The first injection unit/barrel will have 1 gate [A]
The second injection unit/barrel will have 2 gates [B & C] - both gates will open when the flow front reaches that particular area.
When I review the results I would have expected to see 2 XY plots to review independently each injection unit, packing profile, pressure, etc, however, I can only visualizar one general XY plot.
Can you please clarify how to properly visualize pressure related results?
See attached image for further reference.
Hugo Herrera
@Anonymous
Hi Hugo,
maybe you have already sorted this out.
Anyway, reviewing the Analysis Log the information is for master barrel, the default injection location.
This result will be plot "Pressure at injection location:XY Plot"
To visualize results for Sub-barrel injection locations, record the node id for sub-barrel.
Then create new plot Pressure, as XY-plot.
You could record all node id's for injection locations, master and sub-barrel, and put them in same Pressure XY plot.
Or do this for each location.
This could probably be automated by Moldflow API, to find node with boundary conditions for sub-barrel,
and create the Pressure XY plots.
Hope this helps.
Berndt
