Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Moldflow issue when using procedure Cool (FEM)+Fill+Pack+Warp
3 REPLIES 3
nguyenbuulam
62 Views, 3 Replies
Hi Moldflow user and supporters
I am running procedure Cool (FEM)+Fill+Pack+Warp, it required a parameter name
I set Mold Temperature is 100C and "Initial temperature for production start-up for Cool (FEM)" to set 25C,40C,95C but there still have issue and simulation was terminated.
Could you please help me fix this issues ?
Labels (1)
3 REPLIES 3
mason.myers
in reply to: nguyenbuulam
Hello @nguyenbuulam
What is your cooling channel inlet temperatures set to?  Can you try adjusting them to see if that corrects the issue?
Mason
nguyenbuulam
in reply to: mason.myers
Hi Mason
I set Cooling Channel Inlet Temperature with 120C, 95C then this issue still same, simulation was terminated.
Can you help me if there is other solution ?
Thank you for your support.
mason.myers
Hello @nguyenbuulam ,
Where did you set the "Mold Temperature" to 100C?  The mold temperature should be controlled by your cooling inlets.
What is the Ejection Temperature of the material you a molding?
Mason
Technology Administrators
