Hi Moldflow user and supporters
I am running procedure Cool (FEM)+Fill+Pack+Warp, it required a parameter name
I set Mold Temperature is 100C and "Initial temperature for production start-up for Cool (FEM)" to set 25C,40C,95C but there still have issue and simulation was terminated.
Could you please help me fix this issues ?
I
Hello @nguyenbuulam
What is your cooling channel inlet temperatures set to? Can you try adjusting them to see if that corrects the issue?
Mason
Hi Mason
I set Cooling Channel Inlet Temperature with 120C, 95C then this issue still same, simulation was terminated.
Can you help me if there is other solution ?
Thank you for your support.
Hello @nguyenbuulam ,
Where did you set the "Mold Temperature" to 100C? The mold temperature should be controlled by your cooling inlets.
What is the Ejection Temperature of the material you a molding?
Mason
