Macro / Script for Valve Gate Controller
brian6V3ZM
brian6V3ZM
Is there a way to reference a Valve Gate Controller in a script?
When selecting nodes and triangles, the recorded macro will have entities listed
Ex.      EntList.SelectFromString "T18418 T18423 T18424 T18429 T18430 "
When selecting a Valve Gate Controller, the entity list is blank, and only beam shows up in the selection window
Ex.      EntList.SelectFromString ""
adevadkar
HI  @brian6V3ZM ,
You can use
Set VGProp = PropEd.FindProperty(30030, VGno.)     to Get the Valve Gate Controller
VGProp.name to Get the Valve Gate Controller Name
VGProp.ID to Get the Valve Gate Controller ID
Thanks & Regards,
Anirudha D
(If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
brian6V3ZM
Thank you for your reply, but I am still not understanding how to reference a specific controller.  For example to simply delete a controller.
To delete a triangle #T78367, my script macro is this:
Set EntList = MeshEditor.CreateEntityList()
EntList.SelectFromString "T78367 "
Set EntList_1 = MeshEditor.Delete(EntList)
What would be in the quotes for the controller if it has ID = 2 and name is VG-2
adevadkar
Hello  @brian6V3ZM ,
In moldflow you cannot delete the controller, it is associated with the beam element, you can't delete it you are allowed to modify only. (Through Automation). You can do it manually
Delete all the beam (not curve) associated with the valve gate controller and remesh the study to generate new beams.
Thanks & Regards,
Anirudha D
brian6V3ZM
OK, thanks so much for the reply.
