Hello Moldflow Community,
May I ask why I can get ejection temperature by TCode 1504, but can't get Observed nominal shrinkage by 4040 using the same way?
Also can't get below values:
Observed shrinkage 4041
Transfermation temperature 1550
Mechanical properties data 1602
You can try some material have Observed nominal shrinkage value, like Cycolac BDT6500(Trade name)
Thanks!
Solved by bernor_mf. Go to Solution.
Hi @Anonymous ,
to access some of the material property data via the API has been restricted.
This is by design.
Hence not possible to extract the data.
A reason for this this is is also to avoid dumping the whole material database.
Now, when a simulation is completed you could get some data from Analysis Log :
Transition temperature
API example: Extract information from screen out file
Hope this helps.
Berndt
