Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
How to get Observed nominal shrinkage value by API?
2 REPLIES 2
500 Views, 2 Replies
Hello Moldflow Community,
May I ask why I can get ejection temperature by TCode 1504, but can't get Observed nominal shrinkage by 4040 using the same way?
Also can't get below values:
Observed shrinkage 4041
Transfermation temperature 1550
Mechanical properties data 1602
You can try some material have Observed nominal shrinkage value, like Cycolac BDT6500(Trade name)
Thanks!
Tags (1)
Labels (1)
  • API
2 REPLIES 2
bernor_mf
Hi @Anonymous ,
to access some of the material property data via the API has been restricted.
This is by design.
Hence not possible to extract the data.
A reason for this this is is also to avoid dumping the whole material database.
Now, when a simulation is completed you could get some data from Analysis Log :
Transition temperature
API example: Extract information from screen out file
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Tags (3)
in reply to: bernor_mf
OK, Thank you! bernor_mf
Technology Administrators
