Gravity effect prediction Insight 2023 version
prabu_Karunakaran
prabu_Karunakaran
Hello all,
Is Moldflow 2023 version predicting Gravity effect? because i did the same simulation at 2017 with 2018 version , Filling prediction was good at 2018. with current version 2023 , looks like not good prediction . anybody has same experience?
Replies (9)
mason.myers
Hello @prabu_Karunakaran ,
I have recently used 2023 with gravity and the results looked correct to me (I apologize - it was a customer part and I can't share).  Could you re-run with turning off Wall Slip just to focus on the gravity/inertia comparison?  I am not sure if we made any changes to wall slip (or gravity) since 2018.
Mason
prabu_Karunakaran
Hello Mason,
This simulation i did with 2023 without Wall slip effect
Prabu K
mason.myers
I went back and checked all of the solver updates since 2018.  While I know the 3D solver has gone through several updates since v2018, I wasn't able to link your change in filling to any specific solver update.
I would suggest creating a support case and having our support team take a look at your actual .sdy files.
Mason
mason.myers
Hello again @prabu_Karunakaran ,
I just had another suggestion.  Can you (or did you) remesh the model in 2023?  You might see slightly different results by remeshing and solving in the 2023 version.
Mason
prabu_Karunakaran
Hi Mason.
I will try and let you know
Prabu K
prabu_Karunakaran
Hello Mason,
Comparing to the reality 2018 Version predicted well.
As per your suggestion i did new mesh with 2023 version and simulated again with the same version.
Prediction is not good , not comparable with reality
Prabu K
mason.myers
Thank you @prabu_Karunakaran ,
I can't see the complete material you are using but I looked at 3 of the closest materials in the public database and they all appear to be updated in 2018-2022.  I am not sure if this would have an impact on the gravity effect but it's worth noting.  We always suggest that you use the material card tested for the Moldflow version you are using.  For example, we do not recommend you use a .udb file tested for 2017 in the 2023 version of Moldflow Insight.
Mason
prabu_Karunakaran
Hi Mason,
As per your suggestion ,I did the simulation again with updated material , result still the same , i would recommend Autodesk to consider and solve this issue ASAP
Prabu K
mason.myers
Thank you again @prabu_Karunakaran ,
Are you able to share your .sdy files with me so I can share them with our development team?
thanks again,
Mason
