Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Beam of cold gate
3 REPLIES 3
ersin_degin
432 Views, 3 Replies
Beam of cold gate
Hello Moldflow Users,
I have a question about gate meshing.When i meshed as the cold gate.The head of cold gate is not straight.How to fix this.
Thanks.
3 REPLIES 3
bernor_mf
in reply to: ersin_degin
@ersin_degin
the runner and gate are 1D elements, a line, with properites, hence no 3rd point for orientation.
How graphically displayed is by design, using global axis as reference.
The solution and results are not affected by the beam orientation.
From pedagogical point of view, it could raise questions, but just needs to be explained I would say.
Have a look at this discussion:
Unable to create the feed system with LCS using beam element
You probably need to adjust node at gate/cavity interface.
Might have been merged during meshing, and node at end of gate beam moved.
But not sure it will resolve the display issue.
Hope this helps somewhat.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
ersin_degin
Thanks @bernor_mf
You are right and it was solved. 😊
adevadkar
@ersin_degin While merging node first select the gate node then mesh/element node.
