Audi Report
Audi Report
KlausMüller8028
Message 1 of 9
Audi Report
KlausMüller8028
Unfortunately, the Audi report does not run through can someone tell me what the reason is
Replies (8)
Message 2 of 9
raalteh
Hi Klaus,
Which version of the product did you use for this? The Moldflow 2023 FCS version had some problems but we solved a lot of them in Moldflow 2023 Update 1 we released yesterday.
Hanno
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
Please add the following to the end of your Community
Let us know how we did on Trustpilot.
Message 3 of 9
KlausMüller8028
Hi
I have Moldflow 2023 Update 1 install
Message 4 of 9
raalteh
Hi Klaus,
It looks like the plotmanager has a problem finding the Fill Time result.
I tried a few things:
1) The script seems to run fine on my machine (US English OS)
2) I tried to start the script without having a Study open... there is a dialogue asking you to open a study (correct!)
3) I tried to start the script on a model without results --> it produces a dialogue indicating you need results.
4) I tried to start the scrip on a model with ONLY cooling results (no filling result) --> Crash ... but the crash is happening in a different place than yours ... Regardless .. this scenario needs error handling.
I will try to connect with you. There may be things related to the German OS that I cannot do myself.
Hanno
Hanno van Raalte,
Message 5 of 9
KlausMüller8028
So that the Audi script runs without errors, the option legacy mode must be activated under Options/General.
Message 6 of 9
juan.zamora.ruiz
Autodesk Support
Autodesk Support
Hi Klaus,
I managed to reproduce the issue you reported. The message is raised while processing slide 7 of the report, and triggered by a preceding issue when processing slide 6.
To prevent this behavior, rename the study in Synergy before running the Audi report by using only:
  • Characters in the ranges A-Z, a-z, and 0-9.
  • Underscore characters instead of spaces.
Best regards,
Juan Zamora
Juan Zamora
Principal Technical Support Specialist
Message 7 of 9
markus_atteneder
I've tested the new Audi Report, but I don't get deflection results. The generator stops at slice #11 with the sinkmark result.
When I try to start at 16 (deflection results), I got only the first two slices, but no deflection result.
I've tried in english and german, same problem.
Regards Markus
Message 8 of 9
juan.zamora.ruiz
Autodesk Support
Autodesk Support
Hallo @markus_atteneder ,
Thank you for reaching out, I'm sad to know that you're experiencing this issue. I tried to replicate myself, with all tmesh types (MP, DD, and 3D) and it worked in all cases for me. I'm running 2023 with update 2.
We may need some collaborative troubleshooting to understand what could be triggering the behavior in your environment. For an easier troubleshooting I suggest we move to a support case, and we eventually update this forum thread with the outcome.
Best regards,
Juan Zamora
Juan Zamora
Message 9 of 9
markus_atteneder
Hello Juan.
Sounds good, please open a case.
Regards Markus
