API - Tcode reference and MessageID
Hi community,
I have trouble getting values from tcodes. For example, I want to extract pvT coefficients with tcode 1004 or mechanical properties data but I didn't manage to succeed... Do you have scripts to help me ?
Also, I tried to use SystemMessage.GetDataMessage but is there a list of all the messageId that can be extracted from this method ?
Thank you for your help
bernor_mf
Hi @Anonymous ,
I believe PVT coefficients might be protected for this kind of extraction.
Is available in tcode, but could be for write only.
Here is a way to extract data from analysis log:
API example: Extract information from screen out file
For the analysis log, .out file; see details in cmmesage.dat
in folder such as:
C:\Program Files\Autodesk\Moldflow Synergy 2019\data\dat
I did not dig in to how to extract the PVT coefficients using that example, but should be possible.
Share your findings.
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Thank you for your answer. Is this the same for mechanical properties ? I don't know how to read them
Thank you
bernor_mf
yes, and tcode 1621.Mechanical properties data, for thermoplastics material.
It is in the cmmesage.dat file.
MSCD 1621 6 0 0 0 0 0 5
       Mechanical properties data:                    E1  = %11.4G
                                                      E2  = %11.4G
                                                      v12 = %11.4G
                                                      v23 = %11.4G
                                                      G12 = %11.4G
    Pa,1,1
    Pa,1,2
    ,0,3
    ,0,4
    Pa,1,5
In Pa, so you need to recalculate the found data to MPa.
Berndt
bernor_mf
Just wanted to add:
to use this way of getting data, you need to run at least a Fill analysis, to get an Analysis Log to read.
Berndt
thank you for your explanations but could you give me more ? What shoudl I do with E1 = %11.4G ? or with Pa,1,1 ?
bernor_mf
have a look at examples:
' Read Maximum Injection pressure and the time it occurred
' return the array of numerical values associated with the last instance of Message ID (MSCD) 41400
' MSCD 41400 1 0 0 0 0 0 5
'       Maximum injection pressure          (at %11.4G) = %11.4G
'    s,1,2
'    Pa,1,1
' Note: Please see .../data/dat/shared/cmmesage.dat for format details
Set MM = lMessages.GetMessage(41400,0)
lStr = "Maximum injection pressure occured at " & CStr(MM.GetFloat(1)) & " Pressure =     " & CStr(MM.GetFloat(0))
MsgBox CStr(lStr)
So for
                                                      E2  = %11.4G
                                                      v12 = %11.4G
                                                      v23 = %11.4G
                                                      G12 = %11.4G
    Pa,1,1
    Pa,1,2
    ,0,3
    ,0,4
    Pa,1,5
Set MM = lMessages.GetMessage(1621,0)
lStr = "E1= " & CStr(MM.GetFloat(0)) & " E2=      " & CStr(MM.GetFloat(1))
MsgBox CStr(lStr)
' or could be:
'lStr = "E1= " & CStr(MM.GetFloat(1)) & " E2=      " & CStr(MM.GetFloat(2))
'MsgBox CStr(lStr)
"What should I do with E1 = %11.4G ? or with Pa,1,1 ?"
> That is format description. You could leave %11.4G
Pa,1,1, is unit, so in Pa which you might want to recalculate to MPa, and the last number, 1, is the position in array of MM.
Hope this clarifies.
Berndt
