Message 1 of 16
2D-3D Warpage differences
03:08 AM
- Mute
- Permalink
- Report
Hello everyone, I'm doing a Fill+Pack+Warp analysis on a part with thickness of 2.5mm and ribs of 0.8mm ; the material used is a PP (Borealis MD231U).
I first chose a Dual Domain analysis, as the mesh match is 93% and reciprocal is 94%, moreover this part could be considered a thin walled one.
The resulting deflection in Z axis is -7.5 / 15.3, which is quite relevant.
Then I decided to try a 3D analysis to compare the results, using the same process parameters; in this case the resulting deflection in Z axis is -1.5 / 1, really very different to the Dual domain ones.
Which one do I have to trust? Any suggestion for the best option to check (small/large deflection, mesh aggregation, etc..) ?
Thanks in advance
Alessio
