CO2 spot cooling
CO2 spot cooling
CO2 spot cooling
Hi All,
Is it possible to perform a CO2 spot cooling in addition to conventional water cooling in MPI?
Please see the link for more details.
http://www.lindeplastics.com/spot-cooling.php
Kiran D'Silva
Berry Global
bernor_mf
using liquid CO2 spot cooling in Moldflow is not an available feature for the moment.
When gas expands, the temperature is very low, maybe around -80C.
An idea could be to use a Mold Insert that are using RHCM (Rapid Heating and Cooling Mold)?
Use a high Glycol content to get low temperatures for a short while?
Not 100% correct, but maybe a way forward to get some results...
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
mppkumar
Hi @Anonymous
Not possible in Moldflow
you can add this enhancement in Moldflow Ideas
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
genejiang
Please post your requirements in Moldflow Idea station: https://forums.autodesk.com/t5/moldflow-ideas/idb-p/91/tab/most-recent
