Current situation:
ejector pins, venting pins, slider gaps and cavity boarders provide the necessary venting at a common injection molding process.
Those venting techniques provide a small, often long gap where air can escape. To create such a gap it is necessary to select node by node within one venting group. Therefore long gaps need a lot of clicks to create a similar venting situation.
Proposal:
Add the option to select a line of nodes by path.
