After performing an overmolding analysis in Moldflow, you have overlayed the fill time results of the first and second shot (overmolding) components. You are then able to select one of these results to activate. Next, when animating through the fill result, the Active component is the one that cycles through the fill animation. It would be advantageous if there was the option to play through the fill animation of both components so that once the first shot/component fills, the second shot/component then fills sequentially all in the same animation.
The attached .mp4 file demonstrates what I would like to see as an option in Moldflow using Snagit video and some minor editing.
Thank you for taking this into consideration!
