Translate>>copy>> delete
Every time we copy the feed system we have to delete the entities from original place. . It will be time saving if we have an option Copy & Delete Original entities to increase workflow efficiency.
7 Comments
Andreas_Roetzer
Hello prakashcheyyar,
can´t you use "Move" instead of "Copy"?
Should lead to the same result.
regards,
Andreas
prakashcheyyar
Yes.. But when we have to Optimize the Valve gating. often we have to copy the feed system from one co-ordinate to another co-ordinate. After copying we have to delete the old feed system.
For Midplane and Dual-Domain, it will take less time. But in 3D Models, its time Consuming method. Every time we copy the feed system we have to delete the entities from original place.
It will be time saving if we have an option Copy & Delete Original entities to increase workflow efficiency.This would save time because we dont have to make a copy and then go back and delete the original.
rick.schneider
If you use move instead of copy it distorts anything else that is connected to what is being moved.
mppkumar
Hi @prakashcheyyar
I have posted the same idea on 05-20-2015, refer the link below Smiley Surprised
https://forums.autodesk.com/t5/moldflow-ideas/after-copy-or-mirror-option-should-be-there-to-delete-...
@raalteh : is there a way to eliminate these kind of duplication of ideas
mppkumar
prakashcheyyar
@mppkumar Is it possible to delete this thread???
mppkumar
@prakashcheyyar
No.. you can't to delete it now... only community manager can
