I know that there are several options to manage the scale while viewing the result but my requirement is different. I would like to adjust the Y axis near to the number which I enter, mostly by keeping a median value (red line in the pic attached) in the graph as zero.
You will understand my requirements better after seeing the attached Picture.
In the pic the original scale values of Y-axis (of deflection) is from -1.025 to + 0.775 . Most of the times when I share this result with other teams or with the supplier they will misinterpret with the higher values here. But the actual deviation (flatness/roundness etc)here is just 0.25 mm.
So I would like to customize the scale like what I have given in left end with red colour.
Here, a simple step is done. adjusted the scale by -0.925.
By seeing this scale, the designer, project managers, suppliers etc. are more relaxed..!!
(No one want to do a lot of mathematical calculations to come to a conclusion. So let us provide them straight away..!! )
Does this make any sense??
