Selecting/Deselecting nodes by Path
Hello Colleagues,
We usually try selecting a list of nodes while using Path Plots/Fill Hole.
It would be great if we can select the list of nodes by path for quick selection.
Secondly adding on to the previous Idea, while selecting nodes in Fill hole command, whenever we keep on selecting nodes and if we select a node by mistake which was not supposed to be selected and we try deselecting the same node, The fill hole command looses the connectivity of nodes. Which creates a chaos in the selection.
Hence we end up selecting the nodes again from the start to complete the process.
I would recommend that when we deselect any node while selecting the nodes for fill hole, it shouldnt miss the combination(path).
Prasad Mahajan
