PCB (FR4) as part insert - Properties
Hello team,
As you may aware, PCB (FR4) is one of the commonly used part insert for over-molding with plastic (mostly thermoset).
I have seen also the below queries where they tried to use PCB as part insert but there are no inbuilt PCB properties readily available for us to choose.
https://forums.autodesk.com/t5/moldflow-insight-forum/material-for-pcb/td-p/9539372
https://forums.autodesk.com/t5/moldflow-insight-forum/thermoset-ovemolding/m-p/11194078#M1614
https://forums.autodesk.com/t5/moldflow-insight-forum/not-able-to-simulate-with-part-inserts-in-reac...
https://forums.autodesk.com/t5/moldflow-insight-forum/insert-surface-temperature/m-p/7015438#M5770
Could you please create an inbuilt generic FR4 PCB grade and make available in the future versions of Moldflow?
Reference: https://en.wikipedia.org/wiki/FR-4#Properties
Thanks & Regards,
Kulandaivel
3 Comments
raalteh
Thank you for raising this idea.
raalteh
Status changed to: Accepted
I'm changing this to 'accepted' and maybe this can be brought into a release. I think this is a good suggestion.
Thank you Hanno for accepting this idea.
