Melt Volume in Grow from result
Multiple gate location has grow from result where we could see varying colours. It would be great if we can have Volume based on the specific gate through examine option. THis helps us to validate the location and addition/modification fro larger parts. Gate contribution with volume values will really help than having varying colurs.
Rajesh PV
4 Comments
madhukeshwart
If you looking for volume through each gate, you can use  'Throughput Results'
But this results are available for Beam gate only & with midplane and DD only.
If you use Trai-elements for Gate also, won't generate 'Throughput Results'
Better we should request for Specific to '3D gates'
madhukeshwart
And also Some one has already asked for " Throghput Results' in 3D
http://forums.autodesk.com/t5/moldflow-ideastation/throughput-result-for-3d/idi-p/4312520
raalteh
Status changed to: Accepted
I think this is a valid idea.
In case you have beam runners, the throughput information will be useful (some improvements for 3D in the 2017 beta).
raalteh
This makes sense. A partial work around exists through throughput results (there is some improvement on this front in the 2017 beta)
