Throughput result for 3D
I'd like to see a throughput result for 3D flow analysis, as it sums up the Flow rate, beams result for the whole analysis.
Otherwise I would have to do Dual Domain flow analysis in parallel just to get this result. Or did I miss anything?
6 Comments
raalteh
JasperJie
I also get this request from a customer event here. The reason is that they want to calculate how long will melt materials staying in each hot runner sessions when they using hot runner system. In 3D flow, we have grow from while there is no volume values from each gate.
raalteh
Status changed to: Accepted
 Hi, Hanno, Has this Throughput result implemented?
 Hi, Hanno, Has this Throughput result implemented for 3D?
raalteh
This was implemented in the 2016 release. The result is a non-default result.
