Interface for machine data to moldflow process setting
The idea is to built a feature in which we can entre the machine data from shop floor (as input) and in the backend it will do the necessary calculation and provide us the Moldflow process setting (as output) at least for the initial launch.
This will helps to corelate us better and give better confidence on Moldflow.
I agree there will be lots of variable that need to be consider but this will be the actual challenge.
2 Comments
bernor_mf
just for information on this topic
Engel, the injection molding machine manufacturer (IMM), has created this for their machines.
▷ Data Transfer Simulation Software and Injection Molding Machine - ENGEL
Would be good though if Moldflow could have some generic input and output for IMM.
Second your idea.
Berndt
FLUENT, we did test Moldflow + simlink with Engel machine.
It was just a Simlink work. Nothing concern in Moldflow Processing setting UI, it just a linkage.
I think..
What Pawar...means ? It is the Synergy UI display and interface with users as a molder operate Molding machine screen.
"Real Machine screen input  in Synergy" is what he said.
If I right..can it agree?
