Instantly display the maximum value of the result and its location
Dear Moldflow users,
When interpreting the results, one of the most important things is to identify the extremes of the results and their positioning. For this reason, it would be interesting to have a tool available to instantly define the maximum and minimum values as well as their positioning on the geometry.
This could for example be integrated in the "Examine" tool.
If you also think this is a good idea, do not hesitate to give a kudo to support the idea.
Thank you in advance for your help,
Best regards,
Serge Gugelmann - Technik
s.gugelmann@ricone.de
RICONE GmbH
Trausnitzstraße 8
D-81671 München
7 Comments
Andreas_Roetzer
This should definitely be implemented!
My colleague (username "HeinzMitter4056") already asked for this feature two years ago:
https://forums.autodesk.com/t5/moldflow-ideas/min-max-result/idi-p/6577704
Please vote for both to increase the chance that this getting implemented soon!
regards,
Andreas
An alternative is to export Moldflow results to a format readable by ParaView, a  much powerful yet open-source (free) post-processing software.
Below you can see the temperature field on a rectangle plate (clipped by half) at the end of packing. Under ParaView you can easily locate extreme values.
If you are interested, please contact me : tianyi.li@promold.fr
Tianyi Li
Research Engineer
Promold, France
Viking.Huang
Good
raalteh
Status changed to: Accepted
raalteh
Actively looking at this. Vale is understood.
raalteh
raalteh
This idea was implemented in the Moldflow 2024 release
