Hello Developer team,
Recently we came across an error: Error :301150 with Autodesk support and we realized (Based on Autodesk support team) that
The investigation has exposed an issue in the code:
- The incident is triggered for large 3D models running large deflection with mesh aggregation disabled and upgrade tetras set to either automatic or all.
- While the model size and type of geometry (ratio of thicker vs thin layer areas) is the driving factor, we cannot estimate beforehand if the incident will occur or not.
- Until a solution is released, the recommended solution for this type of models is run large deflection with mesh aggregation enabled.
- The provided ****ysis had gaps in the node numbering. It is important to make sure the node labels had been squeezed before running any ****ysis --> this we already tried.
With this scenario there was a thought (Knowing it's very much tricky but may doable), Can we have a hybrid mesh (DD+3D) where we can have 3D in complex area where Midesh is not suitable so we have to go with 3D and other area we can keep DD (Thin area / uniform thickness area) to keep element count in control?
I guess other product simulation software has such facility, may be tricky for process but want to check.
Case number to know more: CaseNo:22274199.
Looking forward to having feedback.
