Flow lenght value
Flow lenght value
I would ask to add some new results to the analysis.
these results should be :
- maximum flow lenght value (from gate to last fill zone)
- general flow leght value as colour scale (and also a capabilities to examine value by clicking on model)
Bye
Giampietro
4 Comments
bernor_mf
I second this idea.
A suggestion is also to add a "last point" manually, where length is calculated from injection location to "last point"-symbol with part.
To time consuming to manually measure distances and add up manually....
This could be automated.
Berndt
JasperJie
second this idea!
Just chatted with a MF Engineer in Shanghai, he has run 1000+ cases using different materials in recent years, he want this function (to get flow length from injection location to end of flow point). so he:
1/ To estimate injection pressure loss in future
     Based on his 1000+ cases - using similar material ( so the data on his hand can be re-used)
2/ To assistant him in locating gate  in future design
Also see similar request on:  https://forums.autodesk.com/t5/moldflow-ideas/flow-length-in-flow-path-plot/idi-p/5013908
Regards
Jasper
raalteh
This could be a nice tie into the path line plot...
bernor_mf
To some extent, have it in results like path line plot would help.
Better if this could be available like the Fill Preview then.
Good if not limited to mesh type.
Berndt
